Motorised valve clicking/ticking noise
r4w
30 Sep 2018
Hi, in my new home I have a couple of Danfoss hpa2 valves that I believe are used to separate the heating of the master bedroom with the rest of the house.
I have two Tado smart thermostat that are working with the system.
However, whenever I hear the Tado's relay switch off the heating as it reached the temperature (the boiler is from Ideal), the two valves starts to clicking/ticking until the boiler goes completely off.
I'm wondering if this is normal or if I should raise this with the builder.
Thank you in advance
Can you upload a video of the noise?
Might be spring mechanism or might just be thermal ticking. If both are doing it then may just be normal? Honeywell are the only valves I use.
It’s normal or a bomb. Evacuate the premises and call the bomb squad to be sure.
Good luck.
OMG, I'm calling the bomb squad right away! :D
You know builders, I didn't even know I was getting the valves... figure the brand.
I have taken a video yesterday morning:
Thanks!
Faulty with that noise mate. Or explosion imminent.
I’ll get me tin hat
Is/they are definitely faulty?
Does the thermostat have anything to do with this?
Just asking as I have replaced the original Danfoss Thermostats with the Tado ones, however the heating works correctly until the temperature has been reached.
That's not right at all! I think a wiring issue... Reverse polarity? Sounds like motor is winding the wrong way :eek:
I'm surprised that whoever installed the system didn't notice this before but thank you @dilalio and @jeff the gasman, I'll report this to the builder to be checked.
I just hope they will not make a big noise that I have changed the thermostats.
Cheers
Cheers
They more than likely will. Throw your hand in to save a possible bill.
Might be no bypass fitted and the pump is forcing the valves open on pump overrun, the valves use ac synchron motors so cant be wired reverse polarity.
Thanks, I didn't really think it was a such big issue, as everything is working normally when it's on.
I was stabbing in the dark a bit mate... hence the ? After my reverse polarity comment :D
Thank you all, I'm contacting the builder to have them both checked!
is your pump near the valves ? sounds more like a pump noise rather than a valve fault
