motorised valves
12 Nov 2009
Lancashire
in a nutshell.. what are the following valves used for?
three port diverter valve
three port mid position valve
two port motorised zone valve
and where are these likely to be installed?
IN a nut shell. To control heating systems, and could be fitted anywhere, depends on the system.
Tut, tut, sunshine, using the forum as a cheatsheet is not the way to go about.
When you are on the job, you have to know what it is about; you can't go home and post the question when the punter is looking over your shoulder
had to look there Ben, thought it was Dick Puller!!!!!!!!!!
