    Dismiss Notice
Mould problem bathroom walls - best fix ?
Discussion in 'Decorating and Painting' started by NickCurtis62, 5 Sep 2021.
Thread Status:
Not open for further replies.
  1. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,281
    Thanks Received:
    2,053
    Hertfordshire
    Country:
    I would like to know when it was last decorated, 1974?
    As it looks like there hasn't been much maintenance to the property.
    Andy
  2. Sponsored Links
  3. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,552
    Thanks Received:
    338
    Wales
    Country:
    Insulation would be good, but make sure you also add a vapour barrier (or foil tape the kingspan joints) to avoid interstitial condensation and future issues with the wall.
  4. RonnieE
    RonnieE
    14 Sep 2021
    21
    Thanks Received:
    UK
    Country:
    Removing the mould is one thing but the challenge is to stop it returning - i.e. sorting the cause not the effect.
    Mould needs certain conditions to grow so if you can tick as many of these off as possible it will help prevent it returning.
    Mould likes...
    - Moisture / humidity (obviously more common in a bathroom)
    - Warmth (that usually exists in a house)
    - Lack of air movement / ventilation (extractor fans and windows open regularly)
    - Lack of direct sunlight
    - An organic material to grow on (mould especially likes plasterboard) as a food source
    - Lack of disturbance (usually cleaning)
    - The presence of spores (obviously you have that)
    You don't have to sort all those things but as many as you can will help.
    Hope that helps.
  5. wallcoatingsbloke
    wallcoatingsbloke
    6 Dec 2005
    57
    Thanks Received:
    2
    Devon
    Country:
    Hi, you cannot cure damp and mould internally. Mould is caused by water getting into the house via the exterior walls. Mould is caused by water. If you block an area inside the house, the water will simply find another spot to emerge and then you are back to square one.
    The only failsafe way to stop mould coming into your home is to treat the EXTERIOR walls with a weatherproof wall coating, available from many companies across the UK.
  6. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    9,495
    Thanks Received:
    1,284
    Country:
    That would seem a bit unlikely to help the OP, unless the moisture is entering via the outside walls. Most often, the moisture is generated from inside the home. Further, wall coatings tend to lock-in any moisture in the fabric.
    • Like Like x 1
  7. RonnieE
    RonnieE
    14 Sep 2021
    21
    Thanks Received:
    UK
    Country:
    Sorry but that is not true. In my experience (as someone who does mould remediation work professionally) mould caused by water coming in via external walls is fairly infrequent. It is much more commonly caused by internal environmental conditions (condensation, leak etc) coupled with the right environmental conditions for the mould to flourish (poor ventilation being very common). On many occasions you can resolve mould problems internally by improving the environmental conditions to a situation where mould does not grow.
  8. Sponsored Links
  9. JP_
    JP_
    17 May 2012
    8,421
    Thanks Received:
    488
    Country:
    That's not right. Most bathroom mould is caused internally, from condensation. The solution is to insulate the walls (doesn't have to be loads, just enough to stop condensation), improve heating, and use an extractor fan, and have a trickle vent in the window.
    • Like Like x 1
  10. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,552
    Thanks Received:
    338
    Wales
    Country:
    A bit controversial for your first post in eight years! :)
    • Like Like x 1
  11. JP_
    JP_
    17 May 2012
    8,421
    Thanks Received:
    488
    Country:
    anybody would think he was bias towards external wall coatings as a solution
    • Like Like x 2
  12. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    9,495
    Thanks Received:
    1,284
    Country:
    He is here to promote wall coatings.
  13. Bonni
    Bonni
    11 Jun 2018
    487
    Thanks Received:
    98
    Country:
    Just wash the mould off with bleach and water. Then emulsion. Any staining that comes through, put a stain block on. You could use oil based undercoat, or Zinseer BIN 123, or a product that says stain block.
    But if you don't improve the heat and ventilation, I suggest you buy loads of bleach, stain blocker and emulsion.
    • Like Like x 2
  14. RonnieE
    RonnieE
    14 Sep 2021
    21
    Thanks Received:
    UK
    Country:
    Using bleach is genuinely not a good idea - it can do more harm than good and only provide superficial benefits. A specialist antimicrobial mould product is far preferable.
Loading...
Thread Status:
Share This Page
