- Joined
- 15 Apr 2018
- Messages
- 256
- Reaction score
- 1
- Country
Hi all
I have had the above lawnmower for 7 years now and it seems that every year I get a problem with it.
This year its the return of the problem; runs when primed for a few seconds but then stops.
After looking at various posts and fiddling I realised i had lost the brass jet. So I bought a new carb for it and have just fitted that with new gaskets ( only thing i kept was the fuel pipe from tank to filter)
Still the same old problem. starts and runs for a few seconds and cuts out.
From what I can see there are two ways of adjusting the carb the brass needle jet and the black plastic thumb screw ( which seems to adjust the speed) I set both to middle, no joy and adjusted to no avail. I even took the brass jet out. It ran for longer( maybe 20seconds) and seemed to be hunting but still cut out.
I have removed the airfilter, cleaned the plug. Nothing seems to work.
Any ideas before I just give up
Thanks in advance
Thanks in advance
