mounting a plaster wall plaque
30 Jan 2005
There is quite a bit of wall space above my sash windows and french doors upstairs so I want to stick on some plaster wall plaques.
Can I check if it would be safe to stick on the wall plaques with Liquid Nail.
(I'm in Singapore, where temperatures don't vary much - from 25C to 34C the whole year round, day and night.)
Cheers,
Peter
should be ok for smallish mouldings might be better to seal the backs with pva before gluing to kill any suction on the backs.
I use liquid nail types adhehesives for fixing moulding..they are fine but make sure you use the water based type and not the solvent
Wipe your joints as you go.
Failing that...tile adhesive works well too, not the fix an grout type though.
