Move meter from internal garage to outside
16 Jan 2011
Surrey
Hi - my electricity meter is currently inside my garage and the cable to the meter comes vertically out of the floor to the meter. It must be buried in the garage floor and runs outside somewhere to the road
I'm converting the garage to internal accommodation and knocking through the garage wall, so I need to relocate the meter to outside of the garage.
I've looked into moving the meter and I may need 3 things:
1. UK Power Network to disconnect the existing meter, isolate the existing cable and dig a trench from the road to the outside of my house and run a new cable where the new meter will be located. Cost c£1,000
2. My Supplier (NPOWER) to reconnect the cable to the meter. Cost £free
3. An electrician to connect the Consumer Box to the Meter. Cost £200-300
The question I have is this .... because my existing cable appears in the garage through the floor and because I plan to raise the floor in the garage using timbers, can NPOWER:
a) cut the cable low down before it enters the meter
b) junction box the cable so it's below floor height
c) run a cable to a new meter outside?
All help appreciated
Thanks, Nick
Only UK power Networks or their authorised contractors can work on that cable.
a) There is no approved jointing method to work on a live vertical cable
b) DNO's do not use junction boxes, only resin filled joints that cannot be fitted vertically neither would they fit a joint internally to a property
c) see a & b
However they will not need to excavate back to the road just from wherever the cable goes under your foundations
Any excavation/reinstatement work on your property you can do
