Fridge freezer was working, moved it from neighbours to mine and left it for gas to settle, plugged it in and it would not work! Can someone help please - sure you can you are clever, helpful people! Many thanks! F
In what way?
Is there any sign of life, e.g. an indicator light comes on?
Does the compressor run or sound as though it's trying to?
Has any wire/connector become loose or detached?
Has any part of the compressor's plumbing been bent or crushed in the move?
Has the circuit-breaker for the power socket tripped?
