Moving fusebox 1-2m extending cables with connector blocks
20 Oct 2010
Lanarkshire
Was on a garage conversion and main board had to be moved approx 1-2m, so spark came in and just extended all the cables and reconnecting with connector blocks, need him to do mine and wondered if this was correct
Robert
If the joints are accessable then it would be deemed acceptable. However, I as an electrician would never contemplate doing it. I would be looking for a more reliable, permanent joint ie crimped.
Personally I deem that to be a half job. I don't know of a single electrician that would do the job like that. Not a real spark anyway.
Hope this helps.
Thanks for the reply will leave it then till i am next working next to a spark and ask them how they would do it, only reason i was going with him was he was signing off the job for building control and i thought if he was capable to sign off then he must be good.
Thanks again
Robert
Sadly no.
He could have become registered without ever having to extend cables for a CU move before.
He could have become registered without ever having encountered or been told about anything except connector blocks. Crimps? DIN-rail terminals? ¿Que?
To become a registered electrician the amount of training, and the rigour of the test, that you need for the paper qualification is pitiful.
And the amount of real-world practical experience you need is SFA.
If he used terminal strip connectors (aka choc blocks) then they must be inside an enclosure, of some sort.
Sorry no enclosure just around a dozen or so bits of connector strip for the joins then hidden behind a new plasterboard wall
Robert
Triple rough - they should be accessible.
Don't let this plonker anywhere near your house. He is not an electrician.
He may think he is, and some money-grubbing registration scheme may be happily agreeing with his delusion, but delusion it remains.
Don't think this is uncommon though.
We had a CU moved a few years back by an electrician (pre-part P I believe) - didn't feel it was something we should do ourselves!
Recently had the floor up and found a variety of "joins", mostly in junction boxes which I think would have been legal at the time, but a couple of lighting circuits had been joined on junction blocks. One junction block just lose, the other had been stuffed inside one of the junction boxes for a socket ring.
