N
namsag
Why would he put a second maintap right next to existing ?
Kirk you have access to every book of regs or should have and you ask me if its NCS no its not never has asked for one semi rigid connection it has just never allowed 2.
Rossered your installer will not need photos he should be able to do a simple job such as this without the need of photos of someone elses work
Its not NCS if theres two solid pipes.
Its AR if the meter has two flex's and isnt secured with the use of a bracket at the inlet & outlet.
Its NCS if it has two flex's and is secured.
We at BG arent allowed to half copper up the inlet, its either all in copper or use an anaconda. But we only move them upto two meters and in the same space.
Im going to assume between the copper and the anaconda you installed a secondary ECV?
I want to move my gas meter box by couple of meters to the left so its out of way. At the moment the Transco pipe (plastic inside steel tube) comes out of the ground on the external wall with meter stuck on the end of it. I am not fussed about pipe position as its not that big but I want the meter elsewhere tucked out of way.
What I'd like to do is have a cable or copper pipe at the end of Transco pipe extending to the position where I want the meter. The meter can then be attached on the other end of the pipe. I don't think they recomend using copper on the mains side and the tracpipe we curently have is only a short one. I am then wondering if I can get a longer tracpipe and use that. Is this possible? Plumber doesn't seem to think it is.
Surely this belongs in the combustion chamber pot, not in a public forum??
I wanted my meter moved 12 inches/ 1 foot/300 mill/ 30cm.They wanted over £500 to inspect and over £600 to move it. I was lucky to dig up the soil, take a few bricks out and slide it along.
No matter how illegal it was, if they hadn't tried to mug me, i might of paid £300.
