Moving staircase back 12" - building regs
2 Apr 2007
Armagh
Hi guys
I am remodelling an upstairs bathroom and plan to move a stud wall out by 12". Obviously this will bring it closer to the top of the staircase. I am planning on replacing the handrail and spindles etc. but spotted a complete replacement staircase on Screwfix.
My question is - can you move the lot back by 12" legally (not falling foul of building control)? I know the newel posts etc will have to be replaced/moved and the joists in the landing floor extended etc.
I think of myself as a competent diyer so I should be fit to handle the job (the wife might not agree) :roll: . Just a bit unsure of the technical side of it with regs etc.
Any advice would be very welcome!!!
Thank you
you will need to maintain 2m headroom from stair tread peak to stair ceiling. spindles should be no wider than 100mm at their widest point.
stairs are very heavy!
Thanks for the quick reply noseall
Do you have to get building control to inspect/report when doing the work?
Are there any difficult issues with fitting the stairs to the side wall (how are they fixed - anchor bolts etc.) or to the joists. I'm assuming there will be work involved with tidying up the plasterwork and floors again afterwards, but the actual relocation should be relatively straighforward - I hope :lol: .
Thanks again
try and mimic the fixing of the existing stairs or even improve upon it and you should be ok. :wink:
Again, thanks noseall.
I checked the height from the riser peak to the sloping stair ceiling, might be an issue. Then again I might try to work around it, raise it slightly. It may end up more hassle than it's worth.
At least I have until the easter week to measure up and decide. :?
Cheers
