A couple of questions relating to repositioning the washing machine I'm afraid. I'll need to replumb for new cold feed and waste pipes, it won't be near the sink or anything convenient like that!
1. There is a mains cold water pipe I can tap into, which presently only feeds the boiler's manual top up inlet. It's in 15mm copper. If I choose to use one of those taps which cuts itself into the pipe, what then happens to the bit of copper cut out? I don't want it floating around in the pipe causing damage.
2. The real pain of this job is going to be the waste. I'll need to run it along a wall for 2m before dropping it down and then through a wall to join the downstairs WC waste under the WC floor (trap first). How much drop do I need to give it as it runs along the wall? How often should it be clipped to the wall?
Anything else worth bearing in mind? I have a certain amount of experience and am comfortable with joining pipes etc.
Many thanks for any advice
JD
JD
