Hi, i've done a bit of reading on this and found useful advice such as bury pipes below the frost line of 750mm.
But i thought best to have some more specific problems addressed...
1. My property is grade II listed.
2. The garage is detached and 2meters away from waste sewer cover in a lawn.
3. The waste sewer is uphill of the garage.
I have had a plumbers opinion whilst he was moving some radiators for me last year. At the time wasn't sure it would be do-able because of the uphill waste, but he said that's the WM waste pump's job.
The level differences are about a foot or two at maximum.
I do have an outside tap but am a bit fussy about showing extra pipe (plus it would freeze?). I think the best route out of the house is by the main tap in the hall by the front door, because it's almost outside pavement height.
I would lift the pavement in front of the front door and bury white plastic flexible pipe under the frost line accross the lawn into the garage (about 6mtrs).
The drainage is what concerns me the most. Any advice?
