better off not paying out for an actuator when the valve body will fail in time to come.
exchange complete valve for a honeywell mid position 3port valve.
change the nuts as well, myson nuts not always fit honeywell but you may be lucky.
dont forget to top up your inhibitor.
Had a feeling the actuator didn't come apart very easily though I think I've done them. But what it says - REPLACEABLE actuator is fair enough. Replace the top bit, = the actuator = the head.
I don't see any reason to do 5 times the work , to replace the whole valve.
There's nothing special about Honeywell valves - they fail too!
Never tried to take the head apart, there are screws on the bottom so maybe you can, but I think I heard different so never tried. Valve actuators are rubbish but can't say I have noticed the valves themselves being any less reliable than any other.
