much difference between kudox prem 600x1200 & 600 x 1400?
11 Jun 2012
I was going to get a 1400 initially but was no stock, guy fitting my new rad said there wouldn't be much difference in heat output with the 1200 so gone with his recommendation, do you think that's probably right? Good bit cheaper as well.
James
If the radiator is big enough to cover heat loss from the room then you'll be ok. On the other hand, if it isn't, then the radiator is too small.
James
They’ll be 15% less heat output. I’d go with the bigger rad if you’ve got space for it.
