Multi Zone Heating Systems
7 Jan 2010
Yorkshire
It's now been 4 years since a new UFH zone was added to my Vaillant setup and it has worked so well I'm considering adding another UFH zone as part of a house bathroom refurbishment project.
Had a quick chat with my installer who says it should be possible using Vaillant products, but based on my previous experience I'm considering using alternatives and wondered what was out there.
When adding the UFH to the existing system, the original VR 65 wiring centre had to be switched for a VR 61, which supports 1 x DHW and 2 x CH zones. In addition a VR 81 controller was purchased as the thermostat for the new UFH area. So, the modifications to the original system weren't that bad.
It appears, to add yet another zone I will need to switch the wiring centre to a VR 71 + VR 70 and replace BOTH my existing controllers for a VRC 700 and a couple of VR 91's. I think I've got all those numbers right! Basically, it is going to be expensive replacing all the existing Vaillant controllers for new Vaillant controllers. If that would "future proof" the system, it might not be so bad, but all it gives me is one extra zone! If the refurbishment of the house bathroom goes well I might consider doing the same to the en-suite bathroom, which will then require an additional zone, but the equipment mentioned above wouldn't be able to include another zone as far as I can tell!
So, what are the alternative heating controllers/wiring centres I could consider to enable multiple zones i.e. at least 5, possibly more?
Does anyone have good/bad experiences of using/fitting multi-zone heating systems?
Thanks.
