Multiple Bluetooth headphones connected to TV?
15 May 2013
Hi all,
I'm wondering if there's a way of connecting more than 1 set of Bluetooth headphones to a TV?
Thankyou
Not sure about using the built in Bluetooth but I believe there are transmitters that allow several receivers to connect.
I use BT senders /headphones at work but all mine are cheap and only connect to one unit at a time.
As said, you’d need an analogue out (probably)
The one above has optical in
Although you might get one with HDMI ARC that would connect via HDMI.
Cheap ones may cause a slight delay?
Thanks for the replies. That device is exactly what I'm looking for. I did see some cheaper ones but shall do a bit of reading of reviews.
Ebay el cheapo
