    Dismiss Notice
Multiple feeds to grid switches
Discussion in 'Electrics UK' started by WeatherMan, 23 May 2010.
  1. WeatherMan
    WeatherMan
    28 Aug 2007
    6
    Thanks Received:
    Yorkshire
    Country:
    Is it permissable to have two feeds into a grid switch?
    I'd like to combine 6 ways (one 20A feed) with 2 ways (second 20A feed) in one 8 way grid box.
    I'm asking because I can see that you would need to trip two MCBs before opening the grid - ie no single point of supply.
    NB I'm NOT proposing any cross-connection between the "6 feeds" and the "2 feeds" so electrically it's OK - just a possible future safety issue if a switch replacement is needed.
    The total load for the combined 8 ways is over 20A - hence the need for 2 supplies.
    Mike
  2. Sponsored Links
  3. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,129
    Thanks Received:
    1,924
    Oxfordshire
    Country:
    Yes it is. The MK grids have a warning label re multiple feeds and the need to completely isolate the grid.
    Good to pop warning notice on the CU too.
    • Thanks Thanks x 1
  4. ColJack
    ColJack
    16 Feb 2007
    11,793
    Thanks Received:
    409
    West Midlands
    Country:
    what the hell are you lighting that requires 20A worth of lights?
  5. londonboy
    londonboy
    22 Feb 2009
    1,582
    Thanks Received:
    149
    London
    Country:
    Who mentioned lighting? :)
  6. OwainDIYer
    OwainDIYer
    5 May 2010
    4,494
    Thanks Received:
    685
    Stirlingshire
    Country:
    Yes, because most MCBs are only single pole devices so they do not count as isolators, which should switch all poles. Isolation for maintenance means using the Big Red Switch on most domestic installations, unless they're fairly recent and have everything on DP RCDs or RCBOs.
    A label inside the switch is a good idea though.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. plugwash
    plugwash
    28 Mar 2004
    9,084
    Thanks Received:
    296
    Country:
    MCBs do get used for maintenance isolation. Whether they should is a contentious point but they do and installers should keep that in mind when they install.
  9. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,129
    Thanks Received:
    1,924
    Oxfordshire
    Country:
    Careful with your assumption. IIRC many (single module) RCBOs only switch the line - they have solid neutral connection.
    • Thanks Thanks x 1
  10. SUNRAY
    SUNRAY
    28 Jul 2009
    2,665
    Thanks Received:
    151
    Kent
    Country:
    Good heavens I had never given this a thought.
    Many thanks.
  11. WeatherMan
    WeatherMan
    28 Aug 2007
    6
    Thanks Received:
    Yorkshire
    Country:
    Thanks to all
    A single 8 way grid and labels it is.
    (It's not lighting BTW)
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
