Sorry to be a pain, but i need to order in the materials this weekend.
What i need to know is:
1) With the 4" round posts, how far should they be below ground?
2) I have reached the sub-base (solid rocks mostly) where the posts will go into, could i have a small trench say 150mm and build up a shutter on ground level of 200mm? So 150mm foundation below ground and 200mm above?
3) Would it be a good idea to use paving slabs concreated in against the earth wall before i put the posts in (To make in a lot stronger), then have a 5" gap between posts and slabs and fill with pea shingle for drainage and protection.
Thanks.
Thanks.
