my Hotpoint LFT321 Dishwasher
7 Mar 2007
Cambridge
I have the above dish washer, i can start it but when it gets into approx 20 mins of the cycle it bleeps 4 times and stops when i open the green led is flashing on the on/off button with the number 8 in the display?
help
It starts runs a bit the dishes are being washed with what I understand cold water then as the programme changes you sort of hear a click then you get 4 quick bleeps and the machine stops with the flashing green led in the on off button and the figure 8 in the display.
I have just spoke to Hotpoint and they are saying there should be a letter before the 8 ????
You got a heater fault. Check the heater with a meter.
How did you come to that conclusion? I also have another problem when the machine is switched off by the on/off button ( so there is no display or lights) I close the door and after some time I will open the door again and the green led will be flashing on the power button and the number 10 will be flashing??? I'm totally confused now.
Error 8 means heater fault. Check it first. Then if that's ok heater relay on pcb has gone.
Lay it on it's back remove base panel it's all there in front of you.
You won't get a diagram there for trade only.
