Hi,i`ve got aproblem with my electric shower.The old one bit the dust and I got a compatible replacement.Worked fine at first but after a couple of days I noticed a smell.Which turned out to be the Isolator switch getting hot.Thinking it was a faulty switch I replaced it.when I switched on, it blew the fuse and burnt out the isolator switch.I replaced the switch again,carefully.The switch jammed up and I noticed the fuse(yes fuse)was getting warm.With my multimeter I found there is continuity between neg and earth.I`m starting to get a bit bothered.I would really appriciate any help/advice.
