Hie all Hie all am pretty new to this forum and I intend building a deck. To be honest I was told to build by the other half lol.
As you guys can see the area I need to build the deck on is made up of clay and gets pretty wet,as the drainage is p**s poor.
The decking area will be 3.6mx3.3m and I intend to create a raised deck about 25cm off the ground.
I have bought some BnQ reversible decking 3.6m lengths
I intend to build the frame using 9x 4x4 posts on which I will put 3x 6x2 joists as beams and for the remaining two sides of the rectangle I shall use 4x2 joists.
Across this frame I shall use 4x joists at 400mm intervals and all the joists will be secured using joist hangers.
What do you guys think
Read more: http://www.diynot.com/forums/floors-stairs-lofts/another-decking-newbie.37
