Strange! As I said, it would be quite hard to design a voltmeter that couldn't cope with a reasonable range of frequencies - and that was as true decades ago as it is today. Ah, wellYeah - I suppose it was about 10 years ago !
Kind Regards, John.
Ah - in the context of the discussions about 50Hz, 100Hz and 1kHz, that's a very significant movement of the goalpostsThe machine welds at 27MHz,
I presume that the possibilities once there is a fault are almost endless! It sounds that even someone who is experienced/competent to work on the machine may have trouble finding a way of doing so safely when it's powered up!.... but what is that doing on the casing of the machine?
Kind Regards, John.
With high levels of 27 Mhz energy in the area an earth lead that shows near zero ohms on continuity with DC test current could have a significant impedance to energy at 27MHz if there are any bends in the cable. This can result in high voltage differences between the ends of the cable. Even running the cable metal to a ferrous object ( girder, iron pipe ) could create an inductive impedance.and did a continuity check on the earth between the wall isolator and the machine?
I can beleive it, particular since, IIRC, the second harmonic of 27MHz would have been in the original TV Band I.I remember as a child, growing up in a house which was 1-2 miles as the EMI flies from a number of furniture factories which used RF gluing machines, how effective they also were as VHF TV jammers.
That's why I said that it would be difficult for even an experienced/competent person to work safely on this machine in its present state. Unless there is something visually obvious, diagnosis could be difficult without the 27MHz generator running, yet the whole thing sounds positively dangerous when it is running. Maybe someone should send for westie and his friensYou are right to walk away from this machine if you are not experienced / trained in the maintainance of 27MHz high power heating.
EDIT If the fault ( voltage that destroyed meter ) is only there when the 27MHz generator is on then the problem will be hard to diagnose without assistance from manufacturer.
Has the cabling to the machine been "tidied up" recently. Such as previously straight runs of cable being re-routed to then have a few bends in them.
Has the machine been moved recently ?
Was it ever intalled properly ?
There may also need to be an earth rod under the machine to disipate stray RF energy. Has that failed ?
