Myra event xs power shower running constantly
9 Jul 2006
Lancashire
My girlfriend has the above shower and today when it was switched off, ie power off and dial turned to the stop position, water continued to flow. The only way I could stop it was to remove the head and hold my thumb over the end of the pipe, for some reason this eventually stopped the water from flowing.
My GF has a plumber coming out from Monday and he has suggested that some parts in the shower are serviceable, however he thinks the problem may be a solenoid that is not serviceable.
Anyway I just wondered if anyone else had any suggestions in the meantime what the problem may be.
Could it be as simple as the on switch that you turn has broken inside so its not going off??
thumb over the end may have triggered an overheat or something?
The shower is defiantly off as the pump in the power shower stops making a noise.
This shower is a powered mixer with a supply from both hot and cold water, it does not actually heat the water.
I had a showerforce 2000 which dribbled when turned off. Solution was a new seal set kit - relatively cheap. Not sure if you have same problem.
We tried the shower this morning and it's now working as normal again :o so I'm not gonna touch it unless it does it again.
Thanks for all the replies.
