Myson Apollo - set to "Hot water only" but radiato
16 Nov 2013
Hi. Currently renting a place with a very old boiler (Myson Apollo). Noticed lately that the radiators are warm, even though the boiler is set to "Hot water only".
Just wondering if it sounds like a big job?
The boiler may be old but its a reliable one. You need to get an engineer to have a look at the motorised valve/valves. Probably anything between £80 and £250 (depending on what needs replacing) would be reasonable
Thanks for replies.
More info - it's just a studio flat on middle floor of converted 3-storey house. 4 radiators in total - 3 small ones (in toilet room, bathroom, kitchen) and 1 larger one in living/bedroom. There's a room thermostat on wall in tiny area between flat entrance door and the 3 doors leading to toilet room, bathroom, kitchen.
In case it helps, a couple of things I've noticed - to get larger living room radiator to heat up properly it seems room thermostat needs to be set to at least 22/23 degrees (which means radiator is either too hot or not hot enough). Used bleed key on it but no difference. Also, with boiler set to "Hot water only", individual radiators seem to randomly go from mildly warm to cold, eg the other day I put a t-shirt on warmish bathroom radiator to dry, but the following morning the radiator was stone cold and the t-shirt was still damp.
As said sounds like a valve issue.
Best to get someone in to have a look and explain the other issues.
