Myson compact CP61 - Replacement Head
4 Oct 2014
London
Good morning all, the pump in our "Potterton Puma 80e" has stopped working. I removed the head and tested it. In needs an initial manual spin to start running. I then replaced the capacitor to no avail.
I would like to know which compatible replacement heads would fit into the existing pump body (less headache I assume).
Your help is very much appreciated. Thank you.
Can someone knowledgeable confirm if I can replace the old Myson CP61 "head" with a CP63 or CP53 "head"?
with the hex socket screws while keeping the old Myson CP61 body/flanges.
