Mystery leak in Roof between Velux Windows
You have tried the velux more than once....A hose with a sprinkler attachment not aimed anywhere specific just on the flat.
ok thank you
will try that
I don’t know if I mentioned but the flat roof has its run off at the front, so any water that goes on the flat roof eventually runs off down the tiles past the Velux windows
so I will certainly do as per your suggestion and run water on the flat roof but it will eventually run down the tiles so I’m worried it will make it still difficult to pin point the leak location
yes i can see the way the roof falls.
to recap you have said you tried the velux twice i believe. so after trying the flat roof and it leaks then you know its the flat roof.
of course you could try the velux again with the hose , let it run naturally and keep clear of the flat roof. save that for after
Hello again
I’ve discovered a new damp patch on the ceiling higher up now.
I’m wondering if the issue is at the flat roof above as previously suggested and is running down between the windows to the original patch I found
there is a vent centrally above in this area (one of three) and I’m wondering if the issue could be there
when it was installed retrospectively (after a building control request) the builder added extra layers of felt and bitumen paint around it, but I’m wondering if this could be the source
any thoughts?
would you say it’s a big job? Could just the front section of the roof be redone? (it’s only 2 years old)
And how urgent would you say based on the patches discovered over the last couple of months
the builder is away but says he can come back next month
To be honest all the felting looks poor never mind the vents.
Get a good felter to look at it close up
To give an update
the builder has returned and replaced the felt at the front section of the roof
I was on the roof with him and saw that the old felt had not stuck sufficiently at the front and had water underneath when pulled up. So it seems that your initial thoughts about the felt being the issue could well be accurate. So thank you for that
hopefully the replacement felt will solve the problem
as an aside, there was some evidence of water inside one of the vents, so it might be that some water is able to get in via a vent in very windy/heavy rain, but I’m hoping that’s minimal and rare and the main issue was the felt which has now been replaced
fingers crossed that does it
thanks for the help and I’ll update if there’s any more issues
