- Joined
- 15 Oct 2004
- Messages
- 18
- Reaction score
- 0
- Country
I recently received a very nasty burn to my left hand whilst making safe a leak to a District heating system.
As I could not find any drain points in the property (a flat which is heated with a communal boiler) I contacted my superviser for advice, and was told to reduce the pressure by turning off all the valves in the airing cupboard and bleeding a rad so to reduce the pressure sufficiently to be able to safely cap off the pipe.
I followed these instructions and as a result of removing a fitting to cap off the pipework, had boiling hot water at full mains pressure gush out all over my hand. I did manage to cap the pipework but needed hospital treatment and am still off work as a result of this (two weeks so far).
What advice would you give to this? Do you suggest I contact my union in respect to making a claim? I am in two minds as this may effect my position with the company I work for and do not want individuals made responsible for what happened. Also what should have been the correct procedure with regards to fixing this leak, was I advised correctly in attempting to reduce the pressure?
any advice would be greatly appreciated, Laurence.
