NEAUTRALIZER PROBLEM
Do you have a cross flow and whats the height from the neutraliser, to the cylinder flow, and what size pipe
and the cross flow :?:
what cylinder is it a modern high recovery or standard
Increase the size of the flow and return to the cylinder,
You could also raise the flow above the cylinder a few feet before dropping back down to the cylinder connection.
Personally i don't think it will ever be satisfactory, as there isn't enough differencial between the flow and return
Wot if i increase just the return out of cyl to 28mm. do u think that might work?
maybe so that could be parastatic circulation, it needs push, I think someone said you should have a minimum 4ft rise on a gravity circuit.
whats the temperature at the bottom of the neutraliser where the return connects
