Hi all, I have ordered a Grohe Talentofill system for my new bath. This is a system which has an intergrated bath filler and pop-up waste so I just need to get some deck mounted valves to control the flow of water into the filler itself. I need some advice though. The water intlet for the filler is 22mm so what size valves would be used to go before this.
Would I need 1/2" or 3/4" valves? I'm also presuming I just get the valves and a Tee fitting so the hot and cold mix at this junction before they reach the single inlet on the filler?
Have seen a few deck mounted tap/valves I like the look of but want to make sure I don't pick up the wrong ones.
Ta!
Ta!
