Need help finding this door seal
It looks like a diy job.
Assuming its an open in door, then usually the door bottom would be rebated and the threshold would have a water bar, although not needed if the door leads to a porch and not the outside world.
The problem you have is that a wiper seal on a door bottom will wear out quickly.
A long term solution, if you want a flat threshold, would be to fit an acoustic drop down seal. It does need a groove in the door bottom, so only suitable if you are proficient at woodwork
https://www.ebay.co.uk/i/3023421377...=1006689&device=c&campaignid=856936013&crdt=0
If you need a rain proof solution, fit a threshold:
https://www.screwfix.com/p/stormgua...aught-rain-excluder-pol-aluminium-914mm/90693
