2) you need a rebated latch, which accomodates overlapping double doors. Presumably you threw the old one away.
3) you need to measure the rebate. I expect it was in one of the common sizes. Yours was a tubular mortice latch with rebate. Unless you are skilled with a very sharp chisel, try to get the exact same one. If you are in UK it might have been Legge or Union. The rebate ends can be added as an accessory to a standard latch. You need to measure the precise length of the backset from centre of handle spindle hole to front of latch.
4) here are some examples from a major supplier. The Altro ones are very high quality.
Thanks so much for your detailed and helpful reply. Lots to unpack here.
You're absolutely right - all the old parts were thrown out at time of doing the job and I've probably learned a lesson there.
I'm fairly skilled with the chisel as I have already had to retrofit 5 other 'standard' door in the house and have found that some good wood filler and paint can go a long way to make up for any minor indiscretions.
I'm going to work through the process you've described but this may not be the last you hear from me.
