I have an issue with my bathroom warm floor in that whenever it's on it will trip the main fuse. It used to woprk o.k., but I had a leak from my thermostatic shower valve within the wall, and part of the job involved pulling up the tiled floor (Initially it was led to believe that the shower trap had a leak). The tiles came up o.k. without disturbing the adhesive and matting within it, therefore a layer of screed was put down on top of that, then new tiles re-laid. Ever since then the warm floor has not worked. An electrician tested the matting when the tiles were removed and it was o.k. Ever since then something has happened that is causing the mat to trip the fuse. Th electrician has tested the mat since and I believe he's found an open circuit.
I'm just trying to see where I can go with this. The original mat was laid down prior to me buying the house 2 years ago, so I don't know the manufacturer. I'm trying to see if I can find a company or individual that can test warm floors with infra red to see where the problem is, so that I can potentially have it repaired.
Please help!!
Please help!!
