Need larger sheet MDF grille - anyone help?
11 Feb 2006
Glasgow
I'm looking for a decorative MDF grille for the back of a cabinet. I can find any number of patterns and finishes online, but they are all 1830mm x 610mm sheets. The space I need filled is 1600mm x 1000mm, so I'd need to join two sheets to fit, which I don't imagine would be either easy nor invisible.
I can find decorative metal grilles of that size, but would prefer MDF or wood.
Anyone know of a supplier that can do larger sheets of MDF grille?
Thanks in advance.
you would need a minimum off 1 support preferably 3 for a sheet that size so settle for 2 sheets with a support between and be prepared to introduce another support each half if nessisery
As mentioned, it would be unstable any larger than available and flap around or bow too easily. :cry:
All true, guys, all true.
However, lets suppose for the purposes of my installation I wanted to buy a larger sheet (and let me deal with the support issue), can I buy one anywhere?
don't think it exists your best bet is to phone/email and ask
i have successfully glued 2 bits together to save buying another sheet but that was a more normal 500x500 size you couldn't see the join when painted and there was no backing
brass comes in 1800x900mm
