    Dismiss Notice
Need to level floor - Mix of concrete and boards
Discussion in 'Floors, Stairs and Lofts' started by diycider, 2 Oct 2019.
Tags:
  1. diycider
    diycider
    16 Feb 2015
    15
    Thanks Received:
    Cheshire
    Country:
    I've just taken up some big horrible flags out of my kitchen that were laid on an inch or so of cement (still to do under kitchen units).
    I plan to put laminate down but the surface is going to need levelling.
    There is a concrete section, boarded section (little uneven) and some channels, one was some water pipes in. I've contacted a few floor fitters, but they aren't responding once I show them the pictures! Either they don't want the work or they don't like the look of the job.
    I'm unsure if I can simply buy some self leveller and pour in the gaps? Or will I need to plywood it all and then pour self leveller on top of the whole floor? It's around 16 square meters in total.
    Appreciate any advice! Picture below.
    [​IMG]
  2. Bonni
    Bonni
    11 Jun 2018
    355
    Thanks Received:
    71
    Country:
    Some levellers will go to an inch thick but I would personally fill the gaps in with 4 parts sand 1 parts rapid set cement, mixed with 50:50 water and SBR.
    Then I would 50:50 Water/SBR the whole floor and whilst still tacky, float down leveller. You could mix bags and pour as you go.
    I've even done 3 parts building sand 1 part rapid cement and 50:50 water/SBR, floated a runny mix down and as it's setting, rub it with a wooden float and sometimes with a brick.
    I only use rapid set cement to get that kind of job done in the day.
    With it going over wood, maybe a laytex self leveller would be ideal.
    • Like Like x 1
  3. Sponsored Links
  4. Nozzle
    Nozzle
    23 Dec 2012
    2,090
    Thanks Received:
    267
    Suffolk
    Country:
    Whatever you do, protect (Denso Tape/conduit) those copper pipes or remove them first!
    Nozzle
  5. diycider
    diycider
    16 Feb 2015
    15
    Thanks Received:
    Cheshire
    Country:
    Ok, thanks.
    Worried about getting it wrong as I know it could be a massive pain to fix.
    My garage floor could do with going over so might practice on that first!
  6. Sponsored Links
  7. dazlight
    dazlight
    6 Apr 2012
    1,500
    Thanks Received:
    239
    Merseyside
    Country:
    I’d put 6mm ply on the wood sections
    Then use primer and tile master levelflex on the channels.
    Then prime and screed the lot at 5mm.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
