neff built in washer
5 Apr 2009
Merseyside
coming up with fault code 04. No info as company went bust before kitchen completion. Any ideas ? thanks
Neff are a Bosch/Siemens company
You should have a Product number and model number on the outer door edge
Usual first suspects are
Flooded base
Pump blocked
Measuring tank/fill tank/pressure chamber clogged with gunk
Does anything else happen when F4 is showing and does that come up straight away or part way through the cycle
Bosch/Siemens/Neff Integrated Washer Dryers (WVTi/WDi & V534)
E01 = Aquastop
E04 = Wash NTC
E05 = No water in
E06 = No water out
E10 = Motor fault
E14 = Dryer NTC
NTC Negative Temperature Coefficient . found next to the heater on washers .dishwashers on the pcb attacted to the door .
