Model U1744SOGB 01
Bought as I was hoping for an easy fix, but now looking for a bit of advice.
The problem arose when someone changing a bulb shorted out the element.
The fan in the bottom oven never turns with the switch in any position. Theres no voltage to it, so I'm assuming thats ok.
The lights for the bottom oven only come on when grill and fan selected. They dont come on if you put the fan oven on, or if you select the lights to come on themselves.
The fan oven element heats up fine, but eventually the cooker rcd trips.
I've had the cct boards off and there is no sign of any damage on them, so I'm hoping they're fine.
The only sign of any problems are what looks like arcing between the rear of the element and the cooker framework.
Has anyone experienced similar? and would changing the element be worth a go first?
Thanks in advance.
Thanks in advance.
