Neff oven door
21 Apr 2009
Cambridgeshire
The rear door on my built-in Neff circotherm double oven does not close fully!
Does anyone know if you can adjust the hinges so that it shuts tighter?
Any help appreciated.
I take it this oven is a type that has a door you lift up to close.
You cant normally adjust the hinges on these.
Where the hinge goes into the oven chassis and locates on the rollers wear occurs.
The rollers being replaced can usually alleviate the problem (some ovens you may need to replace the hinge as well as they can come as a complete set)
