NEFF S5444X1GB/23 dishwasger not filling up - valve issue?
17 Apr 2013
Belfast
hi all
my Neff dishwasher does not seem to fill up with water.
So far I have established there is decent water pressure to the appliance
There is power as motor runs
drain float is not stuck and pump is ok, with no debris in the impeller blades
so..
I took off the aquastop valve, which I believe doubles as a water inlet solenoid. I removed the inline filter and cleaned but it was ok. The valve seems to be stuck in the closed position as I can see two plungers sort of closed.
I have checked the contacts with a DMM and there is a resistance reading of 2.2k ohms. No beep on continuity setting.
I suspect this valve but as there is a reading at all, could this be ok?
any help most appreciated as dishwasher in middle of kitchen with kids attempting to climb all over it
