Neff Warming Drawer
7 Dec 2009
Bedfordshire
Our Neff warming drawer (N22H40N0GB/01) has failed. Google suggests that a common fault with these results in the power led flashing. In our case the power led does not come on at all. (And yes I have checked the fuse in the plug.)
I've been trying to find an assembly drawing to see if I can disassemble in situ (the oven sits on it), but so far with no joy. There would appear to be two potential parts for replacement, but both are expensive, so what to be as sure as I can be of what the problem is before purchasing something. Does anyone have access to drawings, or experience of doing similar?
Not sure if this is similar to your model or if it helps. I would suggest you use a multi meter to fault find with rather than trying a part replacement repair. As you have noticed it could end up being expensive. Pics. might help get you more advice
Thanks. Certainly intend to fault find. My query is around disassembly with it in situ, which I suspect is not possible. But exploded diagram may help decide if that is the case or not
Btw did you mean to include a link?
