Hello all,
I've had a note from a neighbour - they want to remove a chimney which I believe is shared.
The houses are early Victorian, 160 years old and made from sandstone. We are a mid terrace and have a chimney breast in our kitchen which isn't currently used and above this, on their end terrace extension, which is probably almost as old as the main house - they have the chimney in question.
There are probably 5 or more pots/openings on the chimney.
They say that the chimney is dangerous and needs removing, if this isn't done I will be responsible if it collapses. They want to put additional scaffolding on my roof (there is already some on there since repointing has been done - including the chimney).
Should I allow them to do this? What ramifications could it have on my property and what is the correct procedure to follow? I can think of quite a few negatives to this work being carried out. They currently have no building regulations application.
Thanks in advance.
Thanks in advance.
