Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
@^woody^ is on the right lines here I think. If it's >1m from boundary, at that size it's exempt from any regs requirements for substantially non combustible. If it's >2m from the boundary, the 2.5m rule doesn't apply - it goes up to 4m ridge and 2.5m eaves, or 3m flat. The sloping ground is the issue because heights are measured from the highest ground adjacent, so it's quite likely it's all permitted development except possibly the verandah/deck/porch argument. The question would be how interested would council enforcement be willing to test this at appeal, and in any case there is always the possibility of enclosing it so it's no longer "verandah" and just part of the building. An enclosure with bi-folds wouldn't be a verandah and would have the same use.
If it blatantly does not comply with heights and distances for either regs or permitted development, then by all means go after him, but if it's marginal, it may not be worth the animosity, because you might not get the satisfaction you want. Be careful what you wish for - your neighbour might choose to plant tall trees along the boundary, and if they did there would be nowt you could do about it.....(or you could, if it's on your North side)
