Hi all! so, current setup is this:
-oil fired central heating. Boiler is still serviceable and ok.
- gravity fed water system. Insulated copper hot water tank, with immersion heater and boiler in Aga in kitchen.
- water comes from borehole, pumped up to tank in loft.
-Nest controlling central heating system only. Timed spur for immersion heater in summer when aga is off.
We have the opportunity to get onto mains water, which presents some opportunity.
I want to pull out the hot and cold water tanks. Remove boiler in Aga (pretty grim having the hot water go through it) and have an unvented, direct heated hot water tank in the loft, freeing up space in the airing cupboard.
So, I was thinking I could control the timing of the hot water using the nest, wiring up a chunky relay to power the immersion heater in the hot water tank, something like this:
https://www.heatingsave.co.uk/product/immersion-heater-relay/
however, does a direct hot water tank need more current than just a normal immersion heater? I was thinking I might need to run a new dedicated high current circuit for the new hot water system, which wouldn’t be too difficult.
Any other suggestions?
Thanks in advance.
Thanks in advance.
