Hello,
I have a Netaheat Profile 60e. It has started to trip out about once a day. I have read posts about loose joints on PCBs, but I suspect the thermostat. My instruction manual says that I can adjust the temperature between 50 and 85 deg C. They also state that the pump overrun operates when the temperature exceeds 80 deg C. I have my thermostat set to 2, but the pump overrun still runs. Also the temperature of the flow pipe feels far more than 60 deg C. Presumably a failing thermostat would cause these sort of symptoms?
It may or may not be connected, but the case gets quite hot, particularly at the bottom.
I understand that Netaheats can be dodgy to fiddle with, but I also read lots of posts about Corgis turning up and either not knowing what to change, or just changing the expensive bits and not fixing the problem. I would like to be what we like to call at work an "intelligent customer".
