netaheat40e
Status
Not open for further replies.
you can check that your overheat stat has not tripped by opening the little folddown door underneath your boiler on the plastic casing. in there you will find a little red 'button'. Push this in, if it clicks it is lickely that your boiler has overheated.
If this does not work you will be needing a new pcb.
Dont try taking the white cover off the top part of your boiler. It is nt worth the risk and wont help with your boiler repair in any way.
Yes please dont start new threads with the same problem. It just confuses everybody!
AND MAKES US ANGRY!! :D
Status
