A while ago I fitted a new part 2 ball valve to the CWSC, (shutting off the rising main) Because the F&E is fed from cwsc, how would I go about fitting the same to the F&E tank? Thanks in advance.
turn off the incoming stop cock then. It will not take long to swap the valve. You can usually leave the stem in place, undo the large nut and replace the working parts as a sub-assembly.
