Hi everyone.
Before I write to BC with the details I thought I would check here to see what people thought about what I am planning on doing.
Nothing special just add 4 12v (zone 1) halogens and an in line extractor fan (fan in the loft).
The fan will be taken from a spur from the current lighting circuit for the bathroom via a 6 amp fsd. The lights will each have a transformer with 1mm cable on the 12v side (max run no more than 2m). Of course these will be on an rcd.
Fan controlled by pull cord in bathroom with lights via dimmer outside.
Question is as I can't add rcd's to my consumer unit I would need to put one in line before the lights. As I also need to add an FSD for the fan could I install a 2 way insulate enclosure (http://www.tlc-direct.co.uk/Products/HGGD102E.html) and fit an MCB for the fan and an RCBO for the lights ?
Cheers
Rob
Cheers
Rob
