bathroom fan parallel to light is this ok
2 May 2005
Banffshire
in my bathroom which has a big window the wiring is 25 years old the extractor fan (in line about 700mm from vent above shower) is connected in parallel with the bathroom light. so if i switch on the light the fan comes on. is this now illegal? also everything else in the bathroom is on rcd at mains but light (and hence fan) are not. should i change this? finally the light on off pull cord in in the bathroom near the shower (bath/shower). it is not above the bath and is 2.9m from bottom of bath (and 10cm outside of bath edge). is this ok for the pull switch? i could provide power to light and fan from the mains in the loft which is rcd. should i do this?
many thanks for any help
No - is not, and never has been, and is still the most common way to switch bathroom fans.
Is your supplementary equipotential bonding in place?
http://www.diynot.com/wiki/electrics:bathroom-zones
thanks for your kind help
no metal pipes in bathroom all plastic. but immediately outside bathroom all copper pipes are earthed
as you say its not allowed should i get an electrician in or can i leave it as it is 25years old. the fan does not have a timer. should it be on a seperate switch?
what about the light switch?
thaks for your help.
plan B!!
leave lights alone - or better still power them from rcd mains in loft via 3a dp switch in loft but retain pull cord in bathroom?? whould this be allowed?? would it be safer
disconnect fan from parallel arrangement. connect it to rcd mains in loft via 3a dp switch connector. and have a dp pull cord in bathroom to switch the fan on or off. fan does not have timer
would this be allowed?? would it be safe
finally my rcd is on my mains unit. do i need a seperated rcd for the bathroom with a lower rated rcd??
many thanks again
BAS has already said that it's perfectly normal and safe to have the fan paralleled off the light.. so stop messing with it..
if you have a CU that supports it, the easiest way to provide RCD protection to the lights would be to put the whole circuit on an RCBO.. this replaces the breaker in the board.. you'll need a registered sparky to do this.. it works out cheaper than DIY..
ok i am really embarrassed. i am dyslexic and read the first reply the wrong way around. so i thought it meant that it was illegal and wrong and dangerous to have the fan in parallel to the light. i know nothing about this stuff so thanks for all the kind help everyone and forgive me misreading. rob
