I am removing a toilet, basin and bath for a nice white suite. i'm installing an excel thermo mixer shower to put in the stud wall. it is a combo boiler
I need servicing valves for all. I have read on this forum that they need to be full bore so as not to restrict the flow. I am tapping off the pipework for the bath for the shower
i have seen some flush neat looking ones here
http://www.pegler.com/products/inde...oducts|0#Prestex|2#Ball+Valves|43#&template=1
1 will these chrome ones be ok with copper pipe?
2 I was thinking of using yorkshire fittings because of the solder already being there. How do you fit the service valves though. Can you get them with solder in or do you have to solder them yourself?
3 I am going to cut the pipes to the bath v near the taps to remove the bath. the branch off the main pipes to the bath has a further branch off the cold water one for the electric shower which will be removed. i may do the same for the hot water and put a service valve in both to cut off the bath and shower together.
i(a)s this ok?
(b) the branch is not straight-will that make it more aukward?
(c) after a service valve the pipe will be close to the bath so the flexi tap connectors will be bunched up-does that matter
any help is appreciated
i(a)s this ok?
