P
paulabrey
We have had a new gas boiler fitted- Baxi Duo tech combi 28 HE
and after a month are still having problems.
Initially we had heating but the room thermostat had not been wired up to the boiler, so basically it was HOT or HOT.
Apart from two radiators which were extremely patchy after an hour and a bathroom heated towel radiator that was stone cold at the top.
Finally the plumber returned and fitted an RF thermostat. apparently the patchy radiators were down to thermostatic valves and i was reminded that heat rises! However the actual problem was that the raditors only got hot around the whole outer edge. The heat rising idea! Great, but all the other radiators were hot all over and worked fine. After giving himself a shock on the boiler , my concern over his knowledge and competency grew.
Yes he is corgi registered.
He has since returned and believes that we are making up the problems and that radiators are patchy all over when they have thermostatic valves fitted. If this is true , would they not all be the same then?
He has know drained and flushed ( not power) the system down and replaced two valves.
Now the problem is that two different radiators which were piping hot before are now hot on the top and cold on the bottom ( they are vertical radiators). Also the main front rm radiator now barely gives out any heat. It does not have a thermostatic valve on.
The situation is now a stand off, he wants the rest of his money, we feel he is fobbing us off and actually doesnt have a clue what the problem is.
Before the new boiler was fitted all radiators worked great, our problem was that the boiler heat exchange cracked.
To get FULL heat from all radiators ( apart from the front rm) we have to put dial to 30, all the patchiness then disappears.
Any ideas or suggestions greatly appreciated.
