Hi All,
I have asked these questions to my Gas Safe registered installer, whilst I don't doubt his wisdom, I'd like to check second opinions.
Yesterday I had my old floor standing non-condensing Kingfisher Potterton boiler (55% or so efficient!) replaced with a Valiant EcoTec Plus 424 boiler open vented.
The property in question is a 5 bed room, 2 bathroom house, with a gravity fed system (cold water in loft, hot water cylinder on the 1st floor, boiler on the ground floor).
With my old boiler, we just used to switch the hot water on when we needed it (and would have to wait 15-20 minutes for it to heat up, then go for a shower/bath etc.)
The installer said we should just keep the hot water on at all times for on demand hot water, and this wouldn't make much difference to gas usage/efficiency as the boiler would turn off itself when the tank was full.
My question is, is this normal usage of this type of boiler? Leaving the hot water switched on at all times?
Surely in terms of gas usage would it increase? Or not because it would only turn on when the tank temperature drops?
